.flac files to .mp3
shroud
.flac files to .mp3
Post by shroud » Sun Aug 09, 2009 11:15 pm
How do I convert .flac files to .mp3? All the menus are grayed when I play a .flac file so that I can't click on 'export' to make it into mp3.
Re: .flac files to .mp3
Post by kozikowski » Mon Aug 10, 2009 2:43 am
How sure are you that it's a flac file? Did you open it up in QuickTime Player and Apple-I it to get the INFO panel? Typically, Audacity does that when it encounters a damaged file. Does Audacity open up other files and manage them?
Can you open this short piano solo up and convert it?
http://www.kozco.com/tech/piano2.wav
shroud
Post by shroud » Tue Aug 11, 2009 5:03 pm
yes the piano solo plays just fine.
Post by steve » Wed Aug 12, 2009 2:29 am
shroud wrote:All the menus are grayed when I play a .flac file
The menus are grey while you play any kind of file. You need to press "Stop".
