opening Audacity recordings with iTunes by default
shroud
Post by shroud » Sun Aug 09, 2009 11:15 pm
whenever i convert an Audacity recording to mp3 and open it the default is opening with Audacity although I want the defalt to be iTunes. How can I make iTunes the default?
george13
Re: opening Audacity recordings with iTunes by default
Post by george13 » Wed Aug 12, 2009 9:39 am
Try the following:
Highlight a mp3 file in the Finder, right click (or control-click) on it, choose "Get Info"; in the window that is opened, change pop-up menu "Open With" to iTunes, and press the "Change All ..." button.
I personally have all sound files set to open in Quicktime player because iTunes imports everything in its library.
Post by kozikowski » Thu Aug 13, 2009 6:24 am
<<<iTunes imports everything in its library.>>>
Which you can also change. I think the default is to not import.
george13
Post by george13 » Thu Aug 13, 2009 8:42 am
Yes, that's true: you can set iTunes to not make a copy of every song, but everything is imported into the Library database nevertheless.
