label times missing in 'Edit Labels'
mahks
Post by mahks » Sun Aug 09, 2009 9:05 pm
In the edit labels window, the start and end times are all zeros.
Should this not show the current start and end times?
If you export the labels, all the times are there.
waxcylinder
Re: label times missing in 'Edit Labels'
Post by waxcylinder » Mon Aug 10, 2009 9:22 am
Yup this looks like a bug to me (just tested on 1.3.8 Windows XP-HE)- I will alert the developers.
This behaviour did not happen in 1.3.7 (I just tested it) - so it has been introduced in the latest release.
When investigating this I found it hard to find where the "Edit Labels" was located - it is currently available under the Track menu - surely it would be more obvious to locate it under the Edit menu?
Post by Gale Andrews » Mon Aug 10, 2009 5:56 pm
waxcylinder wrote:Yup this looks like a bug to me (just tested on 1.3.8 Windows XP-HE)- I will alert the developers.
OK thanks we'll aim to fix it. It looks like some kind of initialisation problem - you can view and edit the time values correctly if you double-click them and use the TimeText controls (spin boxes). However the times in the exported text files are corrupted because pressing "Export" reverts the displayed times to zero.
waxcylinder wrote:When investigating this I found it hard to find where the "Edit Labels" was located - it is currently available under the Track menu - surely it would be more obvious to locate it under the Edit menu?
We've discussed this before. Functionally, the "Edit Labels" entry is I think in the correct menu, underneath the two "Add Label" items in the Tracks menu. The Edit menu is almost entirely about editing the waveform.
