Changing sample rate (48-44.1 kHz) problems
suburbanDK
Post by suburbanDK » Sun Aug 02, 2009 9:12 pm
When I change the bit rate of a recording I made @ 24-bit, 48 kHz WAV, no noticeable change occurs,
but when I change the sample rate from 48 kHz to 44.1 kHz, tracks lengthen and, not surprisingly, the pitch drops. :shock:
Obviously, I'm trying to make a CD to give to friends. I did initially and found that pitch drop and the fact that all
my song breaks were now wrong when I used "export multiple."
Is there something I should be setting or adjusting?
A single track in 24-bit, 48 kHz that was 4m 25.592s became 4m 49.080s in 16-bit, 44.1 kHz.
TIA,
DrDave
suburbanDK
Re: Changing sample rate (48-44.1 kHz) problems
Post by suburbanDK » Sun Aug 02, 2009 11:09 pm
OK,
so for those of you NOT in the know about this:
The resolution is "Tracks/Resample" and resample to 44100 Hz,
then export a "WAV (Microsoft) signed 16 bit PCM" file.
Post by steve » Mon Aug 03, 2009 3:13 am
It's even easier than that - Just set the "Project Rate" (lower left corner of the main Audacity window) to whatever you want your Exported audio file be, and then Export.
