mahks wrote:I have the same issue, the file name is not the problem, save as 'x.aup' generates the error. The work around is to select all of the current project, copy, create new project, paste and save as. This works every time. Save As then works for anywhere from one to many times before the error 'name.aup is not writeable or the disk is full' is generated again and the work around has to be done.
I've seen several reports of this error on Vista when it is said there is plenty of disk space, and for each one I just said they had to ensure the folder is not "read only", and that they had to be logged in as administrator if they wanted to write outside their user space. I heard no more from any of those people.
Next, there are circumstances where this error is perfectly legitimate. Remember if you have 10 x three-minute stereo tracks in Audacity at 32-bit float resolution, that's 600 MB of space used for each and every edit on the whole project (either in the project's _data folder or in the temporary folder if you never saved a project). Make ten of those edits, you have used 6 GB, this space being the price of unlimited stepwise Undo/Redo. For anyone where this is the problem and you no longer have the space to save the project, click View > History and discard all the Undo levels. You can do this at any stage of the project.
That said, if selecting all of the current project and copying/pasting it to a new project allows you to save it when you couldn't before, there must be some Audacity issue, unless you were previously saving to a folder with a space quota on it. All I can suggest is that if anyone has this issue and it's not due to the reasons I've given, please copy and make a zip file of the .aup file and _data folder, upload it to a free file transfer service such as:
http://www.yousendit.com/
http://www.sendspace.com/
then let us know the web address where we can download it. Obviously this may not be practicable unless it happens on a short project or one with few tracks, but you can discard the Undo history as described above to save space before sending the project file and folder.
Note: if the project contains imported uncompressed files like WAV or AIFF, we won't be able to open the project properly unless the data for those files is copied into the project. To check if the project depends on other files, click File > Check Dependencies.
If you have never saved a project before the problem occurs, you can send us a copy of the autosave file (in effect a temporary .aup file) and the Audacity temporary folder. There will only be an autosave file if AutoSave is enabled in Preferences (in the Projects tab in Audacity 1.3.8).
The autosave file is in the "AutoSave" folder inside Audacity's data directory:
* Windows (except Vista) : Documents and Settings<user name>Application DataAudacity
* Windows Vista: Users<user name>AppDataRoamingAudacity
* OS X: ~/Library/Application Support/audacity
* Linux: ~/.audacity-data
You can find the location of Audacity's temporary directory on the Directories tab of Preferences.
Please try and be on the watch for all actions you take before the error occurs (note them down if you possibly can). If there really is a scenario such as having multiple tracks or offset tracks that causes the bug, that's exactly what we need to find and fix it.
Thanks
