Hi there!
I'm using Windows10 and Audacity 3.0.2. My pc is only a few months old and I still have a lot of free space.
When I press the play button it stops working and then I have to crash it. Already downloaded the newest Audacity version and an older one and it happens with any of them.
Does anybody have an idea of what I should do? There's a lot of work in that project that I'm working on... I'd be very thankful.
Greetings
Janneck
No response when I hit play or rec
Re: No response when I hit play or rec
How were you working on that project?There's a lot of work in that project that I'm working on
What do you mean?kozikowski wrote: ↑Sat Jun 05, 2021 10:59 pmHow were you working on that project?There's a lot of work in that project that I'm working on
I'm working on that for weeks but since last morning it doesn't work anymore.
I record via microfonarray and I have a lot of tracks there. Might it just be too many? That was my latest thought. On the other hand there are by far less tracks than in any song I recorded on my old computer...
How many tracks (approximately) does the project have?
Before going further, best to make a copy of the project so that we can try things with the copy without the risk of adding more problems to the original:
1. Quit Audacity (and wait for Audacity to fully close).
2. Make a copy of the project "AUP3" file.
