Is this the effect you are looking for?
See below, a before and after.
The song is "Beat Thee" from https://freepd.com/
It's creative commons.
How to make audio sound like from a FM radio?
Re: How to make audio sound like from a FM radio?
- Attachments
- Test-1-Raw.mp3
- (418.5 KiB) Downloaded 5 times
- Test-1-EQ.mp3
- (418.5 KiB) Downloaded 3 times
- Test-1-EQ-and-Noise.mp3
JackyBorderCollie
That does not sound anything like FM radio, but more of a night club scene.I want to create a brighter, boomier and louder sound.
Louder is a relative term, you have to decide what is louder, "Amplify" will do that.
As for the brighter an boomier, use the graphic equalizer, probably something around 40Hz, 100Hz, 400Hz and 5KHz.
Plektron Devicer is a free plugin which works in Audacity on Windows.
It has a range of audio device simulations, including "Hi-Fi Stereo".
(The "surround speakers" preset #14 may be what you're looking for )
- Attachments
- devicer.gif (870.63 KiB) Viewed 32 times
You never answered what the source-sound is... Are you trying to make your voice sound like a radio announcer? That's not the "FM radio", that's the announcer's voice and maybe the microphone.I want to create a brighter, boomier and louder sound.
Most professional microphones are directional ("cardioid") and a side-effect of the directional design is the proximity effect which boosts the bass when you get close to the mic. Some male announcers like to take advantage of that effect, but most announces just have a good voice and they don't get that close to the mic. In fact, one of the most popular radio mics is designed NOT to have the proximity effect.
P.S
If you have a good-clean recording and a reasonably-masculine voice you can use EQ (bass boost) to get a similar deep-voice effect.
