Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
mrpaso77
Post
by mrpaso77 » Sat May 29, 2021 4:28 pm
My dts have 3 ch it's LRC when I convert in AC3 it's L R LFE
how can resolve it ???
I don't wont 2 ch!
thx
- Site Admin
Post
by steve » Sat May 29, 2021 9:01 pm
Try a different format, such as WAV or OGG.
mrpaso77
Post
by mrpaso77 » Sat May 29, 2021 9:31 pm
ok I make a wav file and mod time for sinc.
After use eac3to (.videohelp.com/software/eac3to) and make ac3
this old work
- Site Admin
Post
by steve » Mon May 31, 2021 10:38 am
Yes, it's very common for 3 channel AC3 to be encoded as 2.1 (stereo + LFE).
If you want L, C, R, use a different format (such as WAV or OGG).
mrpaso77
Post
by mrpaso77 » Tue Jun 01, 2021 12:58 am
but wav in ac3 has the same error (audacity doesn't work in 3 ch) i solved it with eac3to
mrpaso77
Post
by mrpaso77 » Tue Jun 01, 2021 10:25 am
yep, I am just saying that on 3ch it gives this error
- Site Admin
Post
by steve » Tue Jun 01, 2021 11:46 am
mrpaso77 wrote: ↑Tue Jun 01, 2021 10:25 am
Producing three channel AC3 as L, R, LFE is not an error - that's a standard configuration for 3 channel AC3 and is the default for 3 channel AC3 with FFmpeg.
If you have FFmpeg installed, or another command-line AC3 encoder, it may be possible to achieve different channel configurations using Audacity's command-line export. See:
https://manual.audacityteam.org/man/exp ... ogram.html
mrpaso77
Post
by mrpaso77 » Tue Jun 01, 2021 3:17 pm
thanks I knew about the dts but not about the channels
