I have just downloaded and installed Audacity version 3.0.2 and get the above error message when I open Audacity. I have uninstalled and re-installed, re-booting in between, to no avail. The error log is:
19:07:22: sqlite3 message: (14) os_win.c:46825: (2) winOpen(C:\Users\STEVEN~1\AppData\Local\Temp\audacity_temp\New Project 2021-05-24 19-07-22 N-1.aup3unsaved) - The system cannot find the file specified.
19:07:22: sqlite3 message: (14) cannot open file at line 46826 of [7ebdfa80be]
19:07:22: Failed to open primary connection to C:\Users\STEVEN~1\AppData\Local\Temp\audacity_temp\New Project 2021-05-24 19-07-22 N-1.aup3unsaved: 14, unable to open database file
19:07:22: DBConnection SetError
ErrorCode: 14
LastError: Failed to open database file:
LibraryError: (14): unable to open database file
I have no idea how to get Audacity working correctly. Please Help.
Steve
Error; Cannot open a new empty project [SOLVED]
stevenmlane
Re: Error; Cannot open a new empty project
Does the folder "C:\Users\STEVEN~1\AppData\Local\Temp\audacity_temp\" exist?
If it does exist, are you able to write to it? (Can you create a new file there?)
Do you know what format drive C:\ is? (The default for Windows 10 is "NTFS").
stevenmlane
There is no such user as STEVEN-1, so the folder cannot exist. There is a user stevenlane, the folder C:\Users\stevenlane\Local\Temp\audacity_temp does exist and it can be written to. This is a standard Windows 10 drive, so will be NTFS
One thought is that I had a previous version of Audacity installed, version 2 .something, which I uninstalled before installing the current version. I had not used it for many years
Can you try this:
- Launch Audacity (ignore / dismiss any warnings)
- "Tools menu > Reset Configuration"
- Wait a few moments
- "File menu > Exit"
stevenmlane
YES! Thank you.
Re: Error; Cannot open a new empty project [SOLVED]
Thanks for confirming.
I'll close this topic as"solved".
