Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
gabriel
Post
by gabriel » Wed May 19, 2021 10:24 pm
I wanted to record a voice on a new track and all the other tracks stayed like that, now nothing can be heard. I have been looking for ways to fix it but nothing has come of it. Help please, it's an emergency
here's de picture:
https://postimg.cc/8jg5V2Qy
- problema.PNG (111.88 KiB) Viewed 90 times
jademan
- Forum Crew
Post
by jademan » Thu May 20, 2021 1:21 am
gabriel wrote: ↑Wed May 19, 2021 10:24 pm
I am not sure what you are asking.
(1) If you are using the mute and solo buttons while working with multiple tracks, you may wish to change the option Edit > Preferences > Tracks Behaviors > Solo Button to Multi-track.
(2) If Record (R) does not work properly for you, try Shift-Record (Shift-R). This is reversible by Edit > Preferences > Recording > Record on a new track.
gabriel
Post
by gabriel » Thu May 20, 2021 2:13 am
Sorry for my english ;(, the problem is that all the tracks just went transformed into a horizontal line, so when I play the tracks nothing sounds, and the "mute" option its not even activated. It just went from normal tracks with sound to that horizontal line with no sound.
jademan
- Forum Crew
Post
by jademan » Thu May 20, 2021 11:21 am
gabriel wrote: ↑Thu May 20, 2021 2:13 am
So it looks as though your project has been damaged. It is time to revert to your backup file.
