Limiter
Viktor
Limiter
Post by Viktor » Tue May 18, 2021 9:33 am
Windows 10 Pro, Audacity 3.0.2, Effects, Limiter, Limiter 2, Installed, Enabled, But Not Working?
Re: Limiter
Post by steve » Tue May 18, 2021 10:08 am
Do you have any custom effects installed?
DVDdoug
Forum Crew
Re: Limiter
Post by DVDdoug » Tue May 18, 2021 2:07 pm
What are the symptoms? Have you tried an "extreme" setting?
What are your settings? What are your peaks before & after limiting?*
...The regular limiter may not "appear" to be working if you're using make-up gain.
(I've never tried Limiter II.)
* The quickest way to accurately check the peaks is with the Amplify effect. i.e. If Amplify defaults to +3dB your peaks are currently -3dB. If it defaults to 0dB (no change) your peaks are currently 0dB. (Or if you have ACX-check installed it will also report the peaks.)
Viktor
Re: Limiter
Post by Viktor » Thu May 20, 2021 6:43 pm
Несколько раз сносил и устанавливал заново. На вновь установленной программе, настройки по умолчанию - не работает. На иконке лимитера кнопка прослушать также не рабочая. Скачал другой лимитер, установил, работает.
Google translate:
Several times demolished and reinstalled. On a newly installed program, the default settings do not work. On the limiter icon, the listen button is also not working. I downloaded another limiter, installed it, it works.
