Not responding
cdupertuis1
Not responding
Post by cdupertuis1 » Thu May 13, 2021 3:09 pm
The program is not responding often. I will push one button ie.. mute, unmute, record, etc and its says not responding and will not release for about 3-5 minutes.
cdupertuis1
Re: Not responding
Post by cdupertuis1 » Thu May 13, 2021 4:51 pm
Verson 3.02 - Windows 10 - The program is not responding often. I will push one button ie.. mute, unmute, record, etc and its says not responding and will not release for about 3-5 minutes.
Re: Not responding
Post by steve » Thu May 13, 2021 4:56 pm
Windows 10
Is that an English version of Windows, or another language?
Pillo97
Re: Not responding
Post by Pillo97 » Thu May 13, 2021 10:45 pm
I have the same problem since today last night it was working. (W10pro and Audacity 3.0.2)
I uninstalled and then reinstalled the program but it has the same problem.
The program opens but does not accept any commands. (Only the bar to show/hide the scroll ruler reacts. It moves by "picking it up" with the mouse)
In the lower left corner of the screen, it says "stopped". I tried to check the firewall and antivirus (Microsoft Defender) but I didn't find any blocks.
Help!!!!
Pillo97
Re: Not responding
Post by Pillo97 » Fri May 14, 2021 9:10 am
Resolved!!!!! You need to uninstall the w10 update of May 13, 2121
Perhaps it is useful for developers to find out what the W10 update is about; sooner or later, it will install itself
Re: Not responding
Post by steve » Fri May 14, 2021 11:08 am
Are you using a non-English version of Windows?
Pillo97
Re: Not responding
Post by Pillo97 » Fri May 14, 2021 11:51 am
nooooo
stuck again!!!
I opened it again and it's back stuck as before, it doesn't accept any command, not even on the commands for the size and closing of the window
My windows is in Italian
Re: Not responding
Post by steve » Fri May 14, 2021 12:05 pm
I'm not sure if Italian Windows is affected by this or not, but there was a bug in a Windows update not long ago that caused these symptoms in some non-English Windows installations (https://support.microsoft.com/en-us/top ... a68e328692)
Microsoft have now issued an update to fix the problem, so check that your Windows is fully updated.
