using audacity through Zoom for a talk
Help for Audacity on macOS.
DavidSulzer
Post by DavidSulzer » Wed May 12, 2021 4:43 pm
hi all, I am giving a Zoom lecture and would like to use Audacity to teach people how sine waves add. I can't figure out how to run the sound from Audacity into Zoom, right now it goes through my speakers through a microphone, and then Zoom filters it out. Has anyone figured out how to do this?
best, Dave Soldier
Re: using audacity through Zoom for a talk
Post by kozikowski » Wed May 12, 2021 5:17 pm
How Zoom filters it out may help. Systems with automatic feedback and noise suppression work on the idea that any single tone or sound that hangs around for longer than a set time is obviously noise and get rid of it. These systems are heavily biased toward voices and just hate music.
a Zoom lecture
Maybe this one is going to be a video you post on YouTube.
You and the Royal Institution.
Screen Shot 2021-05-12 at 10.13.52 AM.png (174.1 KiB) Viewed 84 times
It might help a teensy bit if you're on headphones instead of working hands-free. If you're already on headphones, you're stuck.
