How to record streaming music with Audacity 2.4.2
CluelessInSeattl
Post by CluelessInSeattl » Sun May 09, 2021 4:33 pm
I'd like to be able to record streaming music, but the Audacity 2.4.2 I have installed on my laptop running Windows 10, only records through the built in microphone on the laptop. How can I change the settings so that it will turn off the microphone and record directly from the music stream?
Perhaps a screenshot will be helpful:
ImageAudacity 2.4.2 Screenshot by Will Anderson, on Flickr
Will in Seattle
a.k.a. "Clueless"
DVDdoug
Forum Crew
Re: How to record streaming music with Audacity 2.4.2
Post by DVDdoug » Sun May 09, 2021 4:49 pm
CluelessInSeattl
Post by CluelessInSeattl » Sun May 09, 2021 8:10 pm
Wow! That was fast! Thanks a million for that near instantaneous reply.
That did the trick!
