Big Sur - Move Along Timeline while Recording and Editing
Help for Audacity on macOS.
LizLiz6
Post by LizLiz6 » Sun May 09, 2021 12:23 am
Hello.
Whenever I am recording or editing, the screen shows and moved up to 9.0 and then does not move along with the recording, so unless I manually slide it, I stop seeing it once the cursor has moved past 9.0. It used to move along and then just stopped and I am not sure why. I tried playing with all sorts of settings etc.
Screen shot shows exactly how much can be seen and how it never moves along with the recording.
Thank you!
Screen Shot 2021-05-08 at 8.22.01 PM.png (526.7 KiB) Viewed 79 times
LizLiz6
Re: Big Sur - Move Along Timeline while Recording and Editing
Post by LizLiz6 » Sun May 09, 2021 12:52 am
Also edit to my post; It's version 3.0.2 and Big Sur is 11.3
Post by steve » Sun May 09, 2021 1:50 pm
Try resetting Audacity: "Tools menu > Reset Configuration", then restart Audacity.
