Shows Minus 6 Seconds hitting Record
rschiller
Post by rschiller » Thu May 06, 2021 4:52 am
Version 2.3.3 When I hit record, the track starts at zero but immediately shows -8 seconds before the start. Playing back the track the same blank -8 seconds shows. The earlier version I had of Audacity did not do this. How do I eliminate the unwanted black 8 seconds before the actual recording?
thank you and best to all
RSchiller
Re: Shows Minus 6 Seconds hitting Record
Post by steve » Thu May 06, 2021 10:31 am
Turn off "Pinned playhead" (click the "thumb tack" icon on the left end of the time ruler, so that it becomes a triangle.
By the way, the current version of Audacity is 3.0.2: https://www.audacityteam.org/download/
rschiller
Post by rschiller » Thu May 06, 2021 9:14 pm
Thank you!
