Split cut or Silence audio?
Help for Audacity on macOS.
Allurajai
Post by Allurajai » Tue May 04, 2021 3:47 pm
In editing, I've been using split cut during pauses in my audiobook I'm recording, but sometimes it's grayed out and I can't choose it. I select the portion to be edited, but can't choose that option. I've tried Silence Audio a few times and it seems to work, but I'd rather choose Split cut. Why is it sometimes not an option and can I change that?
billw58
Re: Split cut or Silence audio?
Post by billw58 » Tue May 04, 2021 4:07 pm
What version of Audacity are you using?
Could you post a screenshot of a project when it is in a state where Split Cut is greyed out?
-- Bill
Allurajai
Post by Allurajai » Wed May 05, 2021 7:28 pm
Sure, Bill. Thank you! Version 2.4.2
Screen Shot 2021-05-05 at 2.59.29 PM.png (503.56 KiB) Viewed 283 times
Post by steve » Wed May 05, 2021 7:54 pm
The current version is Audacity 3.0.2.
Perhaps (I don't remember) Audacity 2.4.2 requires playback to be stopped rather than just paused :?
billw58
Post by billw58 » Wed May 05, 2021 9:26 pm
It does.
Allurajai: If you want the cursor to stay at the point where you stopped, use the "X" key to stop playback.
-- Bill
Allurajai
Post by Allurajai » Thu May 06, 2021 6:31 pm
Thanks, Bill! I'll try that and upgrade my Audacity.
Allurajai
Post by Allurajai » Thu May 06, 2021 6:40 pm
'X' works perfectly! Thank you!
