Noise in exported WAV files
keclan
Post by keclan » Tue May 04, 2021 9:58 am
Hello,
I'm trying to export some audio records as a WAV files with the following properties: 8000Hz, 8-bit Mono, 64 kb/s.
I use "Unsighned 8-bit PCM" as an export option.
In Audacity all records sound clear and fine.
The problem is that all exported files are noisy (expecially on silent sections of the audio).
How can I fix that?
I'm on Windows 10 64-bit.
Audacity version is 3.0.2.
Trebor
Re: Noise in exported WAV files
Post by Trebor » Tue May 04, 2021 11:28 am
How can I fix that?
Try switching off dither, (in preferences) ...
DVDdoug
Forum Crew
Post by DVDdoug » Tue May 04, 2021 1:47 pm
When an analog signal is digitized you get quantization noise (the result of "quantization error".). It's inaudible at 16-bits but at 8-bits you can hear it. It "lives in the background" like regular-old analog noise so it's most noticeable with quiet sounds. However, unlike analog noise it goes-away with "true digital silence".
Dither is intentionally-added noise that's supposed to be preferable to quantization noise.
keclan
Post by keclan » Wed May 05, 2021 8:52 am
How can I fix that?
Thanks for the tip, but the noise is still there.
Oh, now I see, it's the technical nuance of the 8-bit audio. The noise disappears on 16-bits indeed. Thanks for the explanation!
Post by steve » Wed May 05, 2021 10:11 am
That's correct. 8-bit audio is inherently more noisy than 16-bit, which is why 8-bit is never used when high quality audio is required.
Also worth noting that 8000Hz sample rate audio has an upper frequency limit of 4000 Hz, so speech and music will always sound a bit muffled.
(CD quality uses a sample rate of 44100 Hz, which is Audacity's default and has an upper frequency limit of 22050 Hz (slightly less in the real world), which is sufficient for crystal clear speech and music recordings.
Trebor
Post by Trebor » Wed May 05, 2021 12:14 pm
Thanks for the tip, but the noise is still there ...
before-after dither on 8k sample rate.wav
dither adds hiss to 8K audio
(291.22 KiB) Downloaded 4 times
