New color scheme for spectrogram
Anything you think is missing, or needs enhancement, goes here.
dofuuz
Post by dofuuz » Mon May 03, 2021 11:17 am
Overview
I suggest new color scheme for audacity spectrogram, which is more pretty and better representing audio.
It looks like this:
Original for comparison:
Motivation
To make spectrograms that are pretty, better represent audio, easier to read by those with colorblindness, and print well in gray scale.
Here is further readings:
https://bids.github.io/colormap/
https://cran.r-project.org/web/packages ... ridis.html
Audacity's default colormap is quite bad. Especilly when it's printed in grayscale.
Lightness of background and foreground is confusing.
As you can see, grayscale converted colorbar is chaotic. It should be simple gradient of white - black.
There is huge red bending, which makes spectrogram hard to read.
Re: New color scheme for spectrogram
Post by steve » Mon May 03, 2021 11:31 am
Thanks for the suggestion.
Audacity already offers greyscale rendering of the spectrogram, though it does not offer the full black to white range.
https://manual.audacityteam.org/man/spe ... ences.html
First Track000.png (110 KiB) Viewed 1794 times
dofuuz
Post by dofuuz » Mon May 03, 2021 11:33 am
The new colormap
Considerings while making the new colormap (in order of priority):
- Wide range of lightness (almost full 0-255)
- Colorful, wide range of hue, chroma
- Originality, keep magenta-ish feeling
- Aim to be perceptually smooth
- Pretty
I wrote python code for generating the colormap.
https://github.com/dofuuz/audacity-colormap
Execute 'gen_wheel.py' to generate color wheel.
Change constants like ANGLE, OFFSET, CCW... and generate different color wheels.
Obstacles
There are problems for applying the colormap.
Transparency for sync-lock overlay
Currently, audacity spectrogram has transparency for sync-lock overlay
https://manual.audacityteam.org/man/syn ... roups.html
Without disabling this, spectrograms would look like this:
It will affect color even if background is (0, 0, 0) black.
→ I suggest disabling transparency of spectrogram.
Restriction of Theme
Theme is not applicable for new colormap. A theme can use only 5 colors for spectrogram, which is too small for good colormap.
I tried to make 5-color version of the colormap.
Color bendings are clearly visible.
Also, Audacity ignores the "Spectro1", "Spectro1sel" and "SpectroBackground" colors for the sync-lock overlay.
→ So another suggestion: making option to select color scheme independent from theme.
dofuuz
Post by dofuuz » Mon May 03, 2021 11:52 am
I divided posting to attach more than 4 images.... and admin replied between the posts. 😂
This is not a feature request. I already wrote the code to apply it. Here is my pull request.
https://github.com/audacity/audacity/pull/830
I wanted opinions something about artwork, so I posted this post at 'Audacity Artwork and Graphics' forum.
And... admin moved this post to 'Adding Features to Audacity'
I'm not sure where this post should go now.
Anyway, please give me your opinion about new spectrogram.
Thanks!
To admin: Please merge my PR!
Post by steve » Mon May 03, 2021 12:09 pm
Pulls requests are handled by the developers. This forum is primarily for end user support.
I moved this topic here because you are proposing an enhancement to Audacity's feature set. It looks to me like a very viable enhancement and is more likely to attract the attention of the Audacity developers in this part of the forum.
Post by steve » Mon May 03, 2021 12:17 pm
I wanted opinions something about artwork, ...
I think they look terrific.
Tantacrul
Post by Tantacrul » Thu May 06, 2021 12:41 pm
I agree. They look great :)
Paul L
Post by Paul L » Tue Jun 01, 2021 10:29 pm
Hello dofuuz,
As one if the Audacity development team, I say we are still very interested in your contribution.
Could you rebase these changes onto a more recent master branch tip, and force-push again you your fork?
Please also see your private messages on this forum.
Thank you.
Paul Licameli
dofuuz
Post by dofuuz » Wed Jun 02, 2021 5:14 am
I merged upstream master into changes.
BTW, I didn't received any new PM on this form. 🤔
Paul L
Post by Paul L » Wed Jun 02, 2021 11:02 am
I'm sorry, please check your inbox again now.
Do not merge master into your branch. Instead, checkout out your branch (at commit 558bf1e38be74325ee7f73a85ee9caf72d6a745b), and do
git rebase audacity/master
and then
git push -f origin spec-color
(or however you named your remote repos, substitute them for "audacity" and "origin")
I have begun to make some comments on the commits. Please watch for more.
PRL
