I figured out how to hook up the tape player to the mac and record in audacity.
I exported it and it was one long file. Is there an easy way to divide it up into tracks?
turn cassette into cd records just one looong track
maria86004
Re: turn cassette into cd records just one looong track
Yes. While the one, long performance is on the timeline, put a Label (Apple-B) at the beginning of each song you want as a stand-alone music file.
When you're done, File > Export Multiple, and Audacity will create a pile of individual files for you.
Drag the pile into iTunes, create a PlayList, pull them into the playlist and burn the playlist to a CD.
I went into the creation process in a little more detail here.
http://forum.audacityteam.org/viewtopic ... 787#p46545
waxcylinder
See also this topic from the Audacity Wiki: http://wiki.audacityteam.org/index.php? ... ate_tracks
