Begging for help recovering Missing Audio Data Block File(s)
RodeMotu
Post by RodeMotu » Tue Apr 27, 2021 4:19 am
So I am completely gutted right now, I have an audio project due in two days and I just lost three days worth of progress when the program randomly crashed. Now I have an error message saying "warning missing audio data block files" and my two hours of audio are nowhere to be seen.
Is there a guardian angel out there who can show me how to go about trying to recover this project? I am in shambles over this, was just about ready to finish the project and now this is a huge set back.
I am using Audacity 2.4.2 in Windows 10. I attached my .au file and tried to attach the .data files but it wont let me drop the whole folder in there at once. Desperate for advice!
USC_Spring2021_IanBlake_Part3.aup
(350.61 KiB) Downloaded 15 times
Re: Begging for help recovering Missing Audio Data Block File(s)
Post by steve » Fri May 28, 2021 10:11 am
In versions of Audacity prior to 3.0.0, Audacity projects had two parts.
1. The ".aup" file (that you attached)
2. A "_data" folder containing all of the audio data for the project.
In your case, the _data folder would be called: "USC_Spring2021_IanBlake_Part3_data"
My guess is that moved, deleted or renamed the _data folder so Audacity can't find it, and that's why Audacity is complaining about missing data.
Since Audacity 3.0.0, and in the current Audacity 3.0.2, Audacity projects are now a single, self contained ".aup3" file. The new project format is intended to avoid these kind of mishaps.
The current version of Audacity is available via the Audacity website: https://www.audacityteam.org/download/
