Audiobook-Mastering-Macro
Post by kozikowski » Mon Apr 26, 2021 4:59 pm
Audiobook-Mastering-Macro.txt is a shortcut to automatically apply all three
tools in the ACX Audiobook Mastering Suite.
It guarantees the first two ACX standards, Peak and RMS (Loudness).
The last standard, Noise, is up to you, the microphone, and the environment.
It's not an effect. It's a Macro or Batch that runs other effects.
It runs under Audacity 3.0.2 or later.
Install:
Tools > Macros > Import > Audiobook-Mastering-Macro.txt > Open > Inspect > Close Window.
Apply:
Select the chapter, segment, or timeline > Tools > Apply Macro > Audiobook-Mastering-Macro
(498 Bytes) Downloaded 64 times
MariannaMFcave
Operating System: macOS 10.11 El Capitan
Re: Audiobook-Mastering-Macro
Post by MariannaMFcave » Sun Jun 13, 2021 4:21 pm
Thank you with all my heart for this!
Marianna :D
