Effects and selection
Giovani
Post by Giovani » Sat Apr 24, 2021 9:17 pm
Hello.
I have noticed, that some of effects started to work properly, but one problem is a selection. So, for example in Chimes delay (this is Nyquist plug-in) after applying Chimes delay, track is long, as It was before application. For better application, I must create one silent track, which can be longer, than original track and aply this effect after that. It is also same with another effect. I don't know, if It is bug, or not.
Also, some effects works again. Good job.
Re: Effects and selection
Post by steve » Sat Apr 24, 2021 9:44 pm
This one? https://wiki.audacityteam.org/wiki/Nyqu ... imes_delay
That effect will increase the length of the selection. That is intentional. As it says in the plug-in description, it is adding new "chime" notes many times.
Giovani
Post by Giovani » Sun Apr 25, 2021 8:17 am
Ofcourse, but problem is, that selection is same, not as It was before. I don't know, if You understand. Same is in another Nyquist effect. So, I must generate also long silenced track and combine It with sound track.
Post by steve » Sun Apr 25, 2021 9:07 am
No, I don't understand.
Why?
Giovani
Post by Giovani » Sun Apr 25, 2021 9:40 am
OK.
Let me explain. A selection in some effect not must not be same. For example in Chimes delay only one short sound was enough to generate audio, not long sound with a big silence. For example, in delay effect there was one combo box, which was about to change track duration with aplying delay effect. I don't know, how It was in English language, because I still use Audacity in Slovak.
Currently, lenght of selection is same. I don't know, if It is a bug, or not, but It is current situation.
Or, I have applied Accesstrum (accessible spectrum) to sound. It worked again, but It is not full sweeping of sound, only this short form, which I have selected, not as It was before.
jademan
Forum Crew
Post by jademan » Mon Apr 26, 2021 11:24 am
1) If you are still having problems, download and install the most recent version of Audacity, 3.0.2 here: https://www.audacityteam.org/download/
2) If that does not correct the problem, please post sample .wav files with complete instructions and parameters for using the plug-in. Also post screenshots. Please try to describe what it is doing and exactly how that differs from what you expect.
Giovani
Post by Giovani » Mon Apr 26, 2021 11:45 am
I have a latest version of Audacity. Nextly, I can record this example, but with screenshot will be problem. I am blind.
jademan
Forum Crew
Post by jademan » Mon Apr 26, 2021 12:06 pm
It will help if you can post sample .wav files with complete instructions and parameters for using the plug-in. Please try to describe what it is doing and exactly how that differs from what you expect.
Giovani
Post by Giovani » Thu Apr 29, 2021 6:34 pm
OK.
I understand, that You have requested a sound to me.
But, I'll try It differently. In delay effect is item enable change duration. This is combo box and It doesn't change duration, althought It is selected option "yes". So, It don't change duration, althought I selected to change duration. And this thing is also in effects without enabling or disabling this option, so duration must be changed there also.
jademan
Forum Crew
Post by jademan » Thu Apr 29, 2021 9:19 pm
OK, I think I can reproduce this issue. We'll need to get Steve back in here....
