Making song easy to learn
shroud
Post by shroud » Mon Jul 27, 2009 3:24 pm
I would like to make learning songs easier by dissecting a song and making it repeat 3 times after each section.
Re: Making song easy to learn
Post by steve » Mon Jul 27, 2009 4:06 pm
And are you asking how to do that?
If you've not used Audacity before (or even if you have) there are some good tutorials in the "Tutorials" link at the top of this page which will help you get to grips with the basics of Audacity.
To repeat a section - select the section, then click on "Repeat" from the Effects menu. Enter the number of times that you want to repeat it and Click OK.
Do this for each section that you want repeated.
Export (from the file menu) your finished song. If you want to burn it to CD, Export it as a 16 but WAV file and use a CD burning program to burn to CD.
