leveling L & R input
RaulV
Post by RaulV » Wed Apr 21, 2021 9:50 am
I cannot find this possibility in program, manual and forum.
Would want to use it while recording.
Can only find it as correction feature as part of 'normalise' but wonder if that's really doing the job.
Am on Windows 10 and 3.0.0 (meanwhile 3.0.2) fwiw.
Re: leveling L & R input
Post by kozikowski » Wed Apr 21, 2021 10:04 am
Audacity doesn't apply effects, filters, or corrections during recording.
What's the show? What are you recording that's out of stereo balance?
Post by kozikowski » Wed Apr 21, 2021 10:09 am
Normalize is not a second-by-second processor. It works on an overall average and makes one correction. If your show is constantly changing you may need much more serious processing.
Also a problem if the job isn't really "stereo." Left and Right of one performance.
RaulV
Post by RaulV » Wed Apr 21, 2021 1:38 pm
Source audio is stereo music.
The filters etc are applied after the 'recording'. Or is it's ripping? Grabbing?
Post by kozikowski » Wed Apr 21, 2021 2:59 pm
Ripping is where you achieve a sound or other performance file quickly typically taking far less time than the duration of the performance. There are software packages that allow "ripping" of CDs, DVDs, and Youtube content.
Recording is creating a permanent record of a performance in real time. Five minutes into the recording, you're five minutes into the performance.
We still haven't quite reached what you're recording. If you're using a computer microphone or laptop external connection, it's a good bet you're going through the computer's voice processing. This is a serious problem if you use Skype or Zoom. Voice Processing hates music.
So more information would be good.
DVDdoug
Forum Crew
Post by DVDdoug » Wed Apr 21, 2021 4:31 pm
Audacity only applies filters after recording. But Windows does have those "voice processing enhancements" that can mess-up the audio before it gets to Audacity.
Vinyl records? Cassette tapes? etc.?
How bad is it? Does it sound out-ot-balance or are you just seeing it on the waveforms/meters?
Is it just one recording or is there something wrong with your setup?
A slight imbalance can be normal (especially for analog) and it can be fixed. But the peaks don't correlate well with loudness so making the waveforms look equal may not make the sound balanced and it could make it worse.
If one side is super weak it's probably also bad quality and it might be better to make a mono file (which will play out of both speakers) and maybe just kill the low-quality channel.
If you Normalize independently that will match the peaks and it might fix the problem.
Or you can Loudness Normalize independently. But Loudness Normalization gives you unpredictable peaks so you can end-up with clipping (or a file that's too quiet) so after Loudness Normalizing it's a good idea to regular-normalize non-independently before you export.
RaulV
Post by RaulV » Fri Apr 23, 2021 10:11 am
Tks for the response!
I'm no regular user of the prog. It's just one project. Phenomenon is the same with all discs (MD's!) so probably the set up (but they all are recorded with same device as well) Exchanged what I could which were player and cable. Not laptop which also couldn't be switched to line input so using lowest gain.
It's pretty marginal and only noticeable in the bar. Fact that I couldn't find how to adapt it made me think I was overlooking it.
By the way: MME is OK as setting for what I'm doing isn't it? It's nothing special. Files will eventually end up as mp3's.......
Gee, I only now realise: how can I have individual patterns in L & R while being on the mic input which I would suppose to be monaural?
RaulV
Post by RaulV » Thu Apr 29, 2021 2:36 pm
I'm reassured, the recording is stereo which was already likely as I had the imbalance. And had been working with headphones so I would probably have detected monaural sound).
jademan
Forum Crew
Post by jademan » Fri Apr 30, 2021 12:29 pm
... how can I have individual patterns in L & R while being on the mic input which I would suppose to be monaural?
So if you are using the mic input, you may find you will get better results using an external USB device such as the Behringer UCA 202 or 222.
RaulV
Post by RaulV » Thu May 06, 2021 5:37 pm
Thank you!
The mic input is good enough. Happy that it's stereo switching. Put the sensitivity at the lowest.
Still it's stupid! It annoys me most that Sony never made it possible to move MD recordings to the computer. (for everybody)
They were thinking they had to act as policemen..... Fortunately I have never bought any Sony device since those times....
