No waves, just flat lines after audacity crashed
Help for Audacity on macOS.
loro2000
Operating System: macOS 10.12 Sierra
Post by loro2000 » Mon Apr 19, 2021 12:42 pm
Hi. I was working on a project then audacity crashed. When I reopened the project, the audio was gone. Instead of the usual waves, it's just flat lines. Is there any way to fix this? Thanks.
Re: No waves, just flat lines after audacity crashed
Post by steve » Mon Apr 19, 2021 12:46 pm
Probably not.
Which version of Audacity are you using?
Do you recall what you were doing immediately before the crash (what triggered the crash)?
