[solved] Waveform freezes after opening
Please state:
Re: Waveform freezes after opening
Post by steve » Sun Apr 25, 2021 3:14 pm
sparusaurata wrote:
Sun Apr 25, 2021 2:27 pm
Audacity doesn't like the IM module to be set to xim?
It seems that several GTK apps have problems, so my guess is that it's a bug in GTK_IM_MODULE=xim.
