setting envellope control point using nyquest
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Re: setting envellope control point using nyquest
Post by steve » Sat Apr 24, 2021 9:03 pm
Rather than running that first Nyquist code with the Nyquist Prompt, you could convert it into a plug-in and install it.
To convert it into a plug-in, you just need to add a few "header comments" at the top of the script, and save it as a plain text file. Then change the file extension from ".txt" to ".ny".
See here for information about plug-in headers: https://wiki.audacityteam.org/wiki/Nyqu ... in_Headers
You must include all of the "Required plug-in headers" (https://wiki.audacityteam.org/wiki/Nyqu ... ed_headers)
Notice that the code that I posted already has two of the required headers:
Code: Select all
;version 4
;type tool
The first two line of actual code:
Code: Select all
(setf interval 3.0) ;time interval between points
(setf val 0.5)  ;envelop point value
could be converted to slider controls like this:
Code: Select all
;control interval "Time between points" float "" 3 0.1 10
;control val "Point value" float "" 1 0 2
More info about slider widgets: https://wiki.audacityteam.org/wiki/Nyqu ... ce#widgets
