Which Amplify level to use on recorded vinyl
Re: Which Amplify level to use on recorded vinyl
Post by steve » Tue Apr 20, 2021 12:38 pm
paronix wrote:
Tue Apr 20, 2021 8:11 am
If using normalise on a macro with remove dc offset off and normalise stereo off with just the peak amplitute set to say -1db would this be the same as amplify?
To get the same effect as Amplify, "Normalize stereo channels independently" should be off (not selected).
In most cases the "DC Offset" setting will do nothing, but better for that to be enabled so that it can fix problems with DC Offset if present.
In other words, the defaults shown here are ideal for your purpose: https://manual.audacityteam.org/man/normalize.html
paronix
Post by paronix » Tue Apr 20, 2021 1:28 pm
Great, that would be much easier on a macro than doing amplify manually. Ive got about 1800 todo.....
Post by steve » Tue Apr 20, 2021 1:48 pm
That will probably be too many for Audacity to manage all in one go, but macros can usually manage a few hundred files in a batch.
DVDdoug
Forum Crew
Post by DVDdoug » Tue Apr 20, 2021 2:32 pm
1800 songs or albums? There's another consideration - On an album some songs are intentionally louder than others. If listen to whole albums and if you want to maintain the "original artistic integrity" you should make one file for the whole album and normalize the album as a whole before splitting the songs.
And if you're listening to individual songs you should know that the peaks don't correlate well with loudness so if you normalize all of your music some songs (and some albums) will still be louder than others.
...Audacity does have a Loudness Normalization effect which targets an LUFS loudness level instead of targeting the peaks like regular normalization. Loudness Normalization doesn't automatically check for clipping so you probably don't want to use it in a macro. There are 3rd-party volume-matching tools such as ReplayGain, WaveGain, and MP3Gain and they can be configured to avoid clipping. These also allow you to choose between album & track mode and they can batch-process, but I think you have to process on album at a time if you want the album mode.
When I digitize vinyl I normalize the album as a whole, but then I use ReplayGain (usually in track mode) on Winamp or Sound Check on my iPod at playback-time.
paronix
Post by paronix » Tue Apr 20, 2021 2:58 pm
They are all singles.
