Multiple Inputs
dpickett
Multiple Inputs
Post by dpickett » Sat Jul 25, 2009 3:50 pm
Hi,
I love Audacity but as I move into bigger stuff I have hit a snag. I currently record solely with one USB Microphone which all works fine, however, I wish to buy a MIDI to USB adaptor for my Keyboard so I can record Vocals through the USB Mic and the accompaniment through the MIDI to USB connector. This will allow me to listen through headphones to the Keyboard and output it to the PC without making any Keyboard and have the Vocals recorded solo with perfect accompaniment.
But, how do I set Audacity up so that I have two inputs which would be both USB and then record them at the same time? If Audacity can't do this please point me to a free program that can with a tutorial.
Re: Multiple Inputs
Post by steve » Sat Jul 25, 2009 8:22 pm
dpickett wrote:I wish to buy a MIDI to USB adaptor for my Keyboard so I can record Vocals through the USB Mic and the accompaniment through the MIDI to USB connector.
MIDI is not audio. MIDI signals are just control data that allows devices to communicate with each other. You would "record" MIDI data in a Midi Sequencer and use it to control a synth or sound module which may either be a hardware or software device. The synth/sound module would then generate the audio which you can then record.
Audacity is an audio program and does not support MIDI.
I don't know of any good free programs on Windows for audio and Midi, but Reaper is low priced and has a demo version and Cakewalk make some inexpensive versions that support both MIDI and audio.
dpickett
Re: Multiple Inputs
Post by dpickett » Sat Jul 25, 2009 8:30 pm
OK! That's really useful thanks! :D I may just use a Mixer and plug in my Keyboard and Vocal Mic. Still my question applies, if, I kept my USB Mic and used a JACK to USB adaptor how could I record both USBs at once?
Re: Multiple Inputs
Post by steve » Sat Jul 25, 2009 8:47 pm
No. Audacity can only record from one device at a time.
I think that Wavosaur may be able to record from more than one device at a time.
dpickett
Re: Multiple Inputs
Post by dpickett » Sat Jul 25, 2009 9:07 pm
Thanks! I may therefore invest in a mixer so I can just record from that source! Thanks.
george13
Re: Multiple Inputs
Post by george13 » Sat Jul 25, 2009 9:17 pm
Is there something like an "aggregate device" on Windows?
On a Mac you can set up an aggregate (virtual) device with multiple inputs made out of several physical devices. I've used Audacity to record 4 channels (two channels from a firewire audio interface and two built-in audio).
I wonder if something similar isn't possible with Windows or Linux?
Re: Multiple Inputs
Post by kozikowski » Sun Jul 26, 2009 3:38 am
<<<On a Mac you can set up an aggregate (virtual) device with multiple inputs made out of several physical devices. I've used Audacity to record 4 channels (two channels from a firewire audio interface and two built-in audio).>>>
And how did you do that?
george13
Re: Multiple Inputs
Post by george13 » Sun Jul 26, 2009 9:18 am
I actually regretted posting this (on the windows forum, in the role of the smug mac user :? ). But here's how:
In the 'audio midi setup' there's an 'aggregate device editor'. i ticked 'resample' for both, but hopefully, when all are set to the same rate, there's no need to resample.
In Audacity, the new aggregate device turns up as a third input source with 1,2,3, or 4 channels.
dpickett
Re: Multiple Inputs
Post by dpickett » Sun Jul 26, 2009 12:16 pm
Can this be done on Windows at all? It would save me buying a mixer, XLR mic and cables!
Re: Multiple Inputs
Post by steve » Sun Jul 26, 2009 3:13 pm
It can be done on Linux using the ALSA pcm_multi plugin, though doing so requires a bit of hacking, so is not straightforward. There has not been much interest in developing a graphical application for this because of the inherent hardware limitations involved (see below), but there is some information on the subject here: http://alsa.opensrc.org/index.php/TwoCardsAsOne
I'm not sure if it can be done at all on Windows. Perhaps with VAC ? http://software.muzychenko.net/eng/vac.html
There is a free trial version of VAC (Virtual Audio Cable) if anyone has the hardware set-up to test this.
Hardware Limitations:
A major limitation of these solutions is that there is no synchronisation between the sound cards, so the recordings from each sound card will gradually drift out of time from the other sound card(s). It may be close enough for short recordings of a couple of minutes or less, but likely to be a problem on longer recordings. To fix this would require removing the timing crystal from all but one sound card and hard wiring the one remaining crystal to the other sound cards. This will invalidate any warranty.
