Clip Labels!
Anything you think is missing, or needs enhancement, goes here.
RootlessAgrarian
Clip Labels!
Post by RootlessAgrarian » Fri Apr 02, 2021 8:35 pm
Once again I find myself miffed with Audacity label tracks :-)
When doing spoken word news and interview pieces, it's very much BIA to divvy the master recording up into chunks and start dragging them around, shuffling the order, etc. to produce a narrative flow or fit a standard outline. Like playing with your index cards while writing an article.
So right now I'm reducing a big mess of extempore interview to some meaty nuggets, grabbing clips out of the working stereo mix and putting them into a new stereo track, with some space in between so I can see them as separate entities. Each clip contains a topic that my interviewee talked about. So I label those clips (cmd-B on Mac), so I know this one is "The opioid crisis" and that one is "muffin recipes". Then later after I've edited each clip, maybe added some voiceover in between, whatever, I'll drag them closer together and stitch them into one coherent track.
Now comes the catch-22. Say I would like to move one clip independently of the others. But if I do that -- move the clip in the audio track -- its label doesn't move with it. If I select both tracks (label and audio) then I can no longer drag that one clip independently -- both whole tracks scrub when I try to move one clip. So I would have to ... drag the clip in its track, then drag the label in its track, separately, to the new location. Somehow... it's just not what I intuitively expect. I trip over this every time.
Digging back in history I see that I am not quite alone: other people have whimpered on and off about this inability to attach a label to a clip rather than to a time point. So I'm just one more voice in that fairly feeble chorus. I do realise we are a minority here :-) But ideally, I'd like the option of a label that belongs to the clip -- not to the timeline. So that no matter where that clip ends up or how it gets shortened or stretched or whatever, its label goes with it. If it gets split, the label gets cloned with a terminal -1 and -2. So labels not as a separate track, but as an attribute of the clip that would go with it no matter what track it was pasted into.
Obviously if the clip gets merged then there's some label management to do... maybe the label gets really long, as each merged labelled clip appends more text? or maybe if you merge clips, you lose the label and have to assign a new one. I could live with that :-)
This would be particularly wonderful when editing something that needs a lot of SFX. To be able to label your SFX microclips and stuff 'em all into a "toolbox" track, to be grabbed and pasted into the finished product as needed ("phone rings," "foley wood floor," "doorbell" and so on)... perfect.
Of course I have not read the source code and have no idea how "a clip" is represented internally, but in most ways they behave like objects -- they can be moved, copied, cut, pasted, edited etc very much as if they were objects with attributes one of which is a chunk of wav. So would a label attribute be a lot to ask? I guess it must be, since it's never been implemented :-) Maybe the very definition of "clip" is T1 to T2 on track N, and there's nothing else to attach to (no internal Clip Unique ID Number or whatever).
After a quick survey of answers to other people's historical whining about labels, I did find out that cut/paste can be used rather than dragging, which I admit solves my problem in the near term :-) But it's a fair amount of pointy-clicky for what (to me) seems like a very basic action that I do a whole lot. First you have to select on both tracks (label and audio), then copy or cut, then click in one track for insertion point, then re-select the other track, then you can paste and bingo, clip and label are still together. If I don't do the re-select then I get a popup saying I can't paste one kind of track into another... and it's a rather weird way to do a short-distance drag. I mean, it can be done but (for me anyway) it's not intuitive and a kind of hiccup in the workflow.
I realise this sounds like picayune kvetching and to some extent it is :-) But looked at another way, it's a tribute to the overall intuitiveness and ease of use of the Audacity UI. It feels so effortless to do most things, and so obvious how to proceed, that even relatively naive users can successfully edit their podcast or whatever, without a huge learning curve. That's a stellar achievement. And it sets a bar so high that when I do run into something that seems a bit arcane or clunky or non-intuitive, it's a real shock ... and I whine about it :-)
billw58
Re: Clip Labels!
Post by billw58 » Fri Apr 02, 2021 10:14 pm
This gets my vote.
-- Bill
waxcylinder
Re: Clip Labels!
Post by waxcylinder » Sat Apr 03, 2021 11:27 am
If you turn on Sync-lock then the labels should move with the clips (range label and point labels, including point labels within the range of the clip not just the start of it) and this should leave the other labelled clips alone.
I just tested this in W10 with 3.0.0 and this worked fine.
See: https://alphamanual.audacityteam.org/ma ... ack_Groups
And even without sync-locking all you need to do is extend the selection so that it covers both the audio track and the label track.
Peter.
jademan
Forum Crew
Re: Clip Labels!
Post by jademan » Sun Apr 04, 2021 12:57 pm
...all you need to do is extend the selection so that it covers both the audio track and the label track.
Like this...
AnnieNotaMusician
Re: Clip Labels!
Post by AnnieNotaMusician » Tue Jun 22, 2021 7:01 pm
Does it really leave the other labelled clips alone? I can't get it to do that, either using sync lock or by selecting both tracks. And https://alphamanual.audacityteam.org/ma ... e_Shifting says that when using the time shift tool, "All labels within the track group are moved." Are you moving clips using something other than the time shift tool? Cut and Paste works, I think, but is inconvenient when you just want to shift a track a few seconds.
I would add a vote for a feature allowing the intuitive labeling of clips.
waxcylinder
Re: Clip Labels!
Post by waxcylinder » Wed Jun 23, 2021 10:04 am
Testing on ew10 with 3.0.2 and 3.0.3 latest test alpha build
a) it works if i select in both the audio and label track - If I select just the range of the labelled audio the clips can be moved beyond other clips - if I select extra spce either side then the clip and label can only be moved left and right yo the next neighboring label.
b) with sync lock on if I select in the label track only then it works OK
c) with sync-lock off if I select in the label track only then only the label gets moved
I think this is a (minor) bug - I shall log this when I get time. Minor bug as there are easy workarounds.
You may be extremely lucky here, as I think the MUSE team are considering doing this (I have see a recent wireframe test trig with labelled clips). It won't be in the soon to be upcoming 3.0.3 release but could come soon after.
Peter.
waxcylinder
Re: Clip Labels!
Post by waxcylinder » Wed Jun 23, 2021 2:15 pm
Logged as P3 Bug #2813
https://bugzilla.audacityteam.org/show_bug.cgi?id=2813
Bug 2813 - Sync-lock not honored when Timeshifting labels
There is a simple workaround: Select both the label and the audio by clicking in the text of the label.
Peter
waxcylinder
Re: Clip Labels!
Post by waxcylinder » Wed Jun 23, 2021 2:16 pm
And even better in the wireframe demo I saw there was a drag bar on the top of the clip so you could drag it without the use of the Timeshift tool.
Peter.
