setting mp3 bitrate (VBR-CBR)
Questions, discussion and recipes for scripting and batch processing in Audacity.
See also the "Scripting" section of the Audacity manual.
the_hefay
Post by the_hefay » Thu Apr 01, 2021 1:55 am
Hello, just started learning about macros. It looks like I am only missing one piece for my macro string. I want to be able to set the bitrate to a specific setting but I have no idea which macro to use for that. Can someone give me a hint please?
Windows 10
Audacity 3
Re: setting mp3 bitrate (VBR-CBR)
Post by steve » Thu Apr 01, 2021 9:17 am
Unfortunately Macros do not yet support specifying MP3 settings, only the basic file type (WAV/MP3/etc).
Macros will use the setting last used by Audacity for exporting MP3, so the workaround is to export a dummy MP3 file in the required format before running the macro.
Adding exact format support to macros is on the developer's "to do" list.
the_hefay
Post by the_hefay » Thu Apr 01, 2021 3:23 pm
Thanks for the response. Thanks for the idea for a work around.
