suddenly cannot record
slapadelic
Post by slapadelic » Tue Mar 30, 2021 9:50 pm
Using 2.1.0
I've never had issues with audacity before, using it to get back up audio for video essay type projects and to do quick edits to a sample or loop here and there
but suddenly it won't record, I record using a focusrite interface and Blue mic, I have been for years, and just this week it seems, it stopped recording
either will just get a red vertical line that doesn't move or it will act as though it's recording when it isn't
I can always just use other software but it's just a bummer because audacity is usually easier for the things I want to use it for, so any help is appreciated. I have read the FAQs and troubleshooting, and it did not work
jademan
Forum Crew
Re: suddenly cannot record
Post by jademan » Wed Mar 31, 2021 6:59 pm
Using 2.1.0
1) See if Transport > Rescan Audio Devices doesn't resolve your issue.
2) If this happens with Windows WASAPI, have you tried using "MME" ?
3) Is there some reason you are not using Audacity 3.0.0 ?
