CTRL + ALT + I
u_schneider
CTRL + ALT + I
Post by u_schneider » Tue Mar 30, 2021 7:14 am
Hey, I would like to follow [this tutorial](https://www.youtube.com/watch?v=H3g75QUuoKQ) and use CTRL + ALT + I.
Unfortunately, the shortcuts are not working and I find some solutions in the internet, that do not seem to work,
because the versions seems to have changed.
How can I activate this shortcut for the current version?
waxcylinder
Re: CTRL + ALT + I
Post by waxcylinder » Tue Mar 30, 2021 7:55 am
Go to Keyboard Preferences and use the Defaults button and choose the Full set.
See this page in the Manual: https://manual.audacityteam.org/man/key ... ences.html
