My version seems to be 2.0.5. If I click Help, there is no choice for Check Updates. So how do I update my version?
Thank you.
Kevin O'Brien
cannot upgrade
Re: cannot upgrade
Download & run the Audacity Windows Installer for version 3.0.0 from here.
