I can get an MP4 video with stereo sound ("GoPro AVC") plus an extra WAV file with four mono channels recorded with 32-bit floating point ("pcm_s32le") at 48 kHz.
As the HERO 5 has only three microphones (according to the manual), I tried to find out the channel mapping by recording a short video while moving a sound source around.
However the WAV file's recording level is *very* low:
Much lower than -48dB it seems.
My problem now is:
How can I "preview" the audio wave before trying to normalize?
I could successfully "zoom in", but that did not help.
How can I see the wave form?
I'm only an occasional user of audacity, so I might be missing something obvious.
Should I "zoom out" instead?
However I'm hitting the -48dB limit and I didn't find the setting to change it.
Shouldn't Audacity (2.4.2 is the version I'm using) adjust automatically for 32-bit float resolution?
After normalizing the wave-forms to -20dB, I see this (probably quite some quantization errors):
