Screen view / Negative numbers on timeline
bobupthecreek
Post by bobupthecreek » Mon Mar 22, 2021 2:02 pm
After opening a WAV file in Audacity 2.3.2, it lines up flush left on my screen at 0 on the timeline. Good.
But when I hit play - the timeline and WAV file view shift far right on my screen, exposing about 6 seconds of negative timeline.
I must have accidentally configured the timeline to do this? I don't need to see all the negative seconds on the timeline. How do I reset back to "normal" view? - Bob
waxcylinder
Re: Screen view / Negative numbers on timeline
Post by waxcylinder » Mon Mar 22, 2021 3:19 pm
It's because you have enable Pinned play-head.
See this section of the Audacity Manual: https://manual.audacityteam.org/man/tim ... tml#pinned
bobupthecreek
Post by bobupthecreek » Tue Mar 30, 2021 11:28 pm
Thank you WC -- that did the trick.
waxcylinder
Post by waxcylinder » Wed Mar 31, 2021 9:22 am
:) 8-)
