What do you mean by the "cache folder"?CINEPHOBIA wrote: ↑Wed Mar 10, 2021 8:28 amdeleting the audacity cache folder which makes it work fine for 1 task but then dies again
Audacity Running Extremely Slow
Re: Audacity Running Extremely Slow
CINEPHOBIA
What do you by "1 task"? Do you mean like: Apply the Amplify effect works, but then anything else is extremely slow,
or do you mean that it works fine for one project, but then the problem comes back when you start another project?
As you've probably figured out; we can't reproduce the problem, and we're trying to figure out exactly what is happening. We can't see your machine so we only know what you tell us. At this point, I still don't really have a clear picture.
