Audacity Running Extremely Slow
Help for Audacity on macOS.
CINEPHOBIA
Post by CINEPHOBIA » Mon Mar 08, 2021 4:44 am
I'm running Audacity 2.4.2 on Mac El Capitan.
It's running extremely slowly. Took 15 minutes to open a 50 minute .wav.
It was working fine earlier, but then stopped being functional. Has happened a few times now since I upgraded to this version and this OS.
I rebooted, checked Activity Monitor. Nothing suspicious there. Can't figure out the problem.
Anyone got any tips?
billw58
Re: Audacity Running Extremely Slow
Post by billw58 » Mon Mar 08, 2021 4:01 pm
What has changed recently on your computer?
In Activity Monitor, check Disk and Memory.
-- Bill
CINEPHOBIA
Post by CINEPHOBIA » Tue Mar 09, 2021 7:06 am
What changed is I was running 10.6 forever, then upgraded to El Capitan and upgraded to the latest Audacity. It's just not working. It was working earlier that day and then just decided to stop behaving. Even rebooting didn't help. I've read elsewhere that others have had issues running it on El Capitan.
I previously used an older version on 10.6 and used the program for years without any issues whatsoever.
Post by steve » Tue Mar 09, 2021 9:33 am
Do you use an anti-virus app?
waxcylinder
Post by waxcylinder » Tue Mar 09, 2021 12:07 pm
I just tested on my Macbook Pro macOS 11.2.2 Big Sur - using a one hour stereo WAV file
1) 2.4.2 the open/import took 9 seconds
2) 3.0.0 latest RC05 alpha took 7-8 seconds
My Macbook has an SSD (256MB) and not a spinning metal disk.
Peter.
billw58
Post by billw58 » Tue Mar 09, 2021 5:14 pm
Try Tools (menu) > Reset Configuration. You'll lose any customization you've done, but it might help.
-- Bill
CINEPHOBIA
Post by CINEPHOBIA » Wed Mar 10, 2021 2:38 am
Thanks for the reply, but no I don't.
CINEPHOBIA
Post by CINEPHOBIA » Wed Mar 10, 2021 2:45 am
I did that. I uploaded a 40 min .wav file. Took 33 seconds. Not great but usable.
Then I applied Compression. The first quarter went smooth but then it crawled to barely any perceptible movement in the status bar where it just seemed to stall out.
I'm resurrecting my podcast and Audacity is an essential tool for me. Unless anyone has any other recommendations, I'll look into installing an older version of Audacity or backtracking to an earlier OS because it could be El Capitan that's the problem (unfortunately, that's the highest OS my machine will handle.)
billw58
Post by billw58 » Wed Mar 10, 2021 4:54 am
What are you using for storage? Your internal HD or an external USB drive? How full is your internal HD? How much RAM do you have?
Open up Activity Monitor and look at Memory and Disk. Are a lot of disk swaps happening? What is your memory usage?
In my experience the slowness you describe can be due to disk read/writes (page swaps or just Audacity making a lot of disk accesses) when working with a large file. I've seen huge speed improvement moving from an external USB HD to an internal fusion drive, then to an internal SSD.
You can certainly try an earlier version. If you do, rename your current version of Audacity (for example, add "242" to the end of the name) so you can try both versions with the same file and editing operations. You can find earlier version of Audacity here.
-- Bill
CINEPHOBIA
Post by CINEPHOBIA » Wed Mar 10, 2021 8:28 am
Incidentally, here's what I've done to trouble shoot so far....
- tried past versions of Audacity (worked back to 2.3)
- working on an external hd,
- deleting all audacity files (program/program files) off the machine & doing a fresh install
- deleting the audacity cache folder which makes it work fine for 1 task but then dies again
Thanks.
