Fabfilter VST failed to register
Help for Audacity on macOS.
heytherecasey
Post by heytherecasey » Fri Mar 05, 2021 12:23 am
I'm on MacOS High Sierra 10.13.6, and Audacity 2.3.0.
I'm trying to install a handful of Fabfilter plug-ins, and am getting the error message that Fabfilter Pro-Q 3 failed to register.
Normally, in Logic or other DAWs, when you add the plugin to a track, it pops up a screen to enter the product key and register. Anybody how to do this within Audacity?
Re: Fabfilter VST failed to register
Post by steve » Fri Mar 05, 2021 9:31 am
Audacity does not support any "digital rights" mechanisms. Any plug-ins have to be fully operational before they can be used in Audacity.
