Noice Reduction doesn't work / Please help me to fix this audio
Help for Audacity on macOS.
ivana.ivana
Post by ivana.ivana » Thu Mar 04, 2021 10:16 pm
Hi,
I want to remove background sound from audio file, and I tried to do this as many times before but it doesn't work.
When I select sample and open Noise reduction all parameters are 0 (PrtScn is attached).
Do you know what is the reason for this?
Also, I'm adding sound sample from which I want to remove hum back noise, so if you know any other way to do this I would really appreciate your help.
Thank you.
Screenshot 2021-03-04 at 23.07.07.png (1.56 MiB) Viewed 434 times
audio_sample.wav
(510.13 KiB) Downloaded 22 times
billw58
Re: Noice Reduction doesn't work / Please help me to fix this audio
Post by billw58 » Fri Mar 05, 2021 3:21 am
Can you move the sliders for the three noise reduction parameters, or type values into the boxes?
-- Bill
billw58
Post by billw58 » Fri Mar 05, 2021 3:23 am
Just listened to the audio you are trying to fix. The problem is room echo. That cannot be fixed using the Noise Reduction effect.
-- Bill
ivana.ivana
Post by ivana.ivana » Fri Mar 05, 2021 7:17 am
Hi Bill,
thank you for reply.
Yes, I can move sliders, but it's on 0 and it's not possible to lower it.
Do you know any other way to reduce echo?
Thank you a lot.
-Ivana
billw58
Post by billw58 » Fri Mar 05, 2021 3:32 pm
The minimum value for the parameters is 0. See this manual page.
No, I don't know of any way to remove the echo/reverb in your recording.
-- Bill
Post by kozikowski » Fri Mar 05, 2021 3:50 pm
Echoes are very difficult. Echoes are your voice bouncing from walls and arriving at the microphone slightly later than the main voice or performance. The sample sounds like it was made in a hall or other large room, but any room with hard, shiny walls like a bathroom or kitchen will do it.
The job is removing the voice from itself. There is no "noise."
If you find a way to fix this, post back.
Post by kozikowski » Fri Mar 05, 2021 8:48 pm
Can you post that work again, only longer? Same thing only 10 seconds.
ivana.ivana
Post by ivana.ivana » Fri Mar 05, 2021 8:57 pm
Yes, of course. Here it is...
Thanks a lot.
--Ivana
sound_sample.wav
(1.9 MiB) Downloaded 26 times
Post by kozikowski » Sat Mar 06, 2021 12:01 am
I got this to work once on a test sound file.
Look for a simple, clean echo in the dialog. I chose 7.65 seconds to 8.25 seconds. Ideally, the performer would clap once just before speaking. You may have seen some musical performers do that. They're doing it for sound sync, but that's not the only thing it's handy for.
Screen Shot 2021-03-05 at 3.44.58 PM.png (30.21 KiB) Viewed 362 times
Effect > Noise Reduction > Profile.
Then select the whole file and Effect > Noise Reduction: 15, 6, 6 > OK.
It won't get rid of the echoes, but it will suppress the "thick, full, fuzzy, cottony" sound. It will also get rid of a bunch of the background hisss.
sound_sample2.wav
(1.9 MiB) Downloaded 19 times
I think that's the best we can do.
Post by kozikowski » Sat Mar 06, 2021 12:09 am
Just for the record. How was this recorded (if you know)?
I've seen people in the back of a lecture hall trying to record a presentation. I expect it to sound just like this.
