Error opening recording device
Help for Audacity on macOS.
Paulmoon
Post by Paulmoon » Thu Mar 04, 2021 6:48 pm
I've just installed Audacity 2.2.4 on my iMac OS Catalina 10.15.7. The interface i've installed is a Focusrite Scarlett 2i2 - 3rd. Gen.
The 4 boxes just under the menu bar are set to(from left to right) : Core audio - Scarlett2i2 USB - 1 (mono) recording channel - Scarlett2i2 USB
When Audacity opens I get a home page open. When i click on the Microphone icon & click start monitoring a window pops up stating: Error opening recording device. Error code 9986 Internal Port Audio error. I have clicked the ? and was not able to navigate to that error code or find a route to fix this issue. I used Audacity (relevant version of course) a lot about 6 years ago without any issues, and i'm desperate to be able to use it again, please help!
Paul Moon.
billw58
Re: Error opening recording device
Post by billw58 » Thu Mar 04, 2021 8:44 pm
Try setting the recording channels to "2 (stereo) recording channels".
-- Bill
Paulmoon
Post by Paulmoon » Fri Mar 05, 2021 4:09 pm
Thanks Bill, I tried that but just the same error dialog box comes up.
Paul.
billw58
Post by billw58 » Fri Mar 05, 2021 4:26 pm
Go to Apple (menu) > System Preferences > Sound > Input. Is the Scarlet listed there? If you select it and input some audio to the Scarlet, does the input level meter bounce?
-- Bill
Paulmoon
Post by Paulmoon » Fri Mar 05, 2021 9:08 pm
Thank you, yes I've now got to be able to monitor the microphone to set level, but then, when i press the Red record button nothing happens, no recording! No nothing! and no way of knowing what I may be doing wrong if anything!!! reaching the stage of trying another software 😩
jademan
Forum Crew
Post by jademan » Sat Mar 06, 2021 10:19 pm
Windows guy here. Does Audacity have permission to use your microphone?
See: Control access to your microphone on Mac
I hope this helps. :D
Paulmoon
Post by Paulmoon » Mon Mar 08, 2021 4:03 pm
Thanks, I've checked that, and its enabled - but i'm going around in circles. Now gone back to error opening code 9986
I'll shut down and reboot. All seems to work using Ableton lite but I don't like that programme very much.
