Greeting Dears
i seek your help how to fix cut in the sound wave and it cause click sound when i zoom in i see cut in the wave i managed to fix by repair plugin but its a lot in the file and takes forever to find and fix each
Re: how to fix cut in the sound wave
See if this fixes it:
How can I prevent clicky recordings on Mac?
i have checked this page and unfortunately not same topic
i have recorded this music set from my equipment pioneer ddj1000 and through rekordbox
now i'm trying to fix this issue of wave cuts and the sound cause from it
That's irrelevant. Look at the posted screenshot - it is not "a clipped recording".LeslieDevane wrote: ↑Mon Mar 08, 2021 11:02 amTo sum it up for you: The best ways of refurbishing a clipped recording through editing are using equalization and applying compression.
