Hi Guys,
I’m having trouble importing any Mp4 files larger than 2 hours into Audacity. It just crashes.
I’ve installed the FF-Mpeg convertor files and 2 hours is fine.
Any help appriecated.
Thanks
Hi Guys,
Thanks
That shouldn’t happen… The only format that I know of that has built-in limitations is WAV which has a 4GB limit.
No problem for me. I just created and then re-imported an M4A almost 4 hours long (over 500MB). There’s probably something “wrong” with your file… Hopefully something minor…
You might try converting the file to WAV or FLAC with another program before importing into Audacity. If you don’t have an application for that, try [u]Kabuu Audio Converter[/u] or [u]TAudioConverter[/u]
How much free space is there on your C: drive?
I will try clearing it out, thanks fr the reply.
Fixed it, should’ve thought of that. Thanks
