Settings
billw58
Re: Settings
What version of Audacity? What Mac? What version of macOS? What are your current settings in the Device toolbar?
What do you mean when you say that the Blue Yeti is "set up properly"?
-- Bill
-- Bill
Re: Settings
If you have a newer Mac, I'm curious about the adapters. The Yeti came with a large USB-A connector and Macs don't support that any more. How did they deal with that?
