crash when apply effect
Help for Audacity on macOS.
llkkzey
Operating System: macOS 10.14 Mojave
Post by llkkzey » Wed Feb 24, 2021 10:06 am
I used Audacity to modify the sound effects on the MacOS Mojave. When I'm adding effect, just clicking OK might cause a crash. It happens so often that I have to restart Audacity to edit files. How to solve it? Any help would be greatly appreciated.
llkkzey
Re: crash when apply effect
Post by llkkzey » Wed Feb 24, 2021 12:16 pm
Audacity version 2.4.2
os: Mac 10.14.5 Mojave
Post by kozikowski » Wed Feb 24, 2021 12:30 pm
How long is the show?
When was the last time you restarted your Mac?
How many other things do you have running?
Do you use iCloud or other on-line storage?
Post by steve » Wed Feb 24, 2021 12:54 pm
Just some effects or all effects?
llkkzey
Post by llkkzey » Thu Feb 25, 2021 5:01 am
It happens roughly once every three files. The last time I restarted my Mac was a month ago. Usually I just run Unity, Visual Studio and Chrome. I don't use iCloud or other online storage.
llkkzey
Post by llkkzey » Thu Feb 25, 2021 5:04 am
All effects will be triggered and it seem to be completely random
Post by steve » Thu Feb 25, 2021 9:47 am
Try rebooting the computer and see if that helps.
