Windows 10 - Audacity 2.4.2
On my Mac I have the AUGraphicEQ in the lower section of my effects dropdown. For some reason on my PC I don't have that same EQ option.
Does anyone know why?
Is there something I need to download/change to have this EQ on my PC?
Thanks.
Graphic EQ
Re: Graphic EQ
Macs come with built-in effects. Audacity just picks them up in addition to its own and the ones you installed.Mac I have the AUGraphicEQ
Had you bought the right computer, you'd have it on both.
