Hi everyone. I’m a relative newcomer using audacity and am
Running a school radio program with it. There seems to be a lot of echo when I record. Any tips to help with this!
Echo
Re: Echo
What does that mean? What are you recording? From the microphone built into your laptop? From a USB mic or USB interface? Etc?Running a school radio program with it.
...Sometimes you can get an echo if Software Playthrough is enabled but sometimes simply turning it off isn't the best fix.
