"trlal verision"
wadewilson30
"trlal verision"
Post by wadewilson30 » Tue Feb 23, 2021 6:48 pm
I continue to have this issue where audacity will allow me to record like normal for a period of time and then midst recording will stop recording my audio and fill it in with a female voice saying "trial version", ive tried uninstalling the software and redownloading it but the message just comes back. I was under the impression that there is no "trial version" per say and that this software was free ad available to the public.
DVDdoug
Forum Crew
Re: "trlal verision"
Post by DVDdoug » Tue Feb 23, 2021 7:51 pm
Audacity is free and open source and there is no official trial version.
I recommend uninstalling what you have and then download & install the legitimate version linked from https://www.audacityteam.org/download/windows/ (It takes you to fosshub.com for the actual download.)
...It's probably a good idea to run your anti-virus and/or anti-malware program just in case some other junk was installed or maybe something that will interfere with your legitimate Audacity installation.
Post by steve » Tue Feb 23, 2021 8:38 pm
I've heard of a similar complaint that turned out to be a trial version VST plug-in. If you have installed any plug-ins, then worth checking if any of those are trial versions.
Audacity itself (the official version) is free and without limits.
