I am new to Audacity. I recorded hour-long audio with my partner and saved it, which I think was not the way to do it. Anyways, when I saved it, I created a folder on Documents, called, "Podcast" and when I try to open the Episode (the one on the folder named: Episode1.aup) on Audacity, it tells me: "Couldn't find the project data folder: Episode1_data"
Also, when I saved it, it created a folder called "eff" with 4 folders filled with our audio, which is about 3 seconds long each.
I want to be able to open thec.AUP file so I can edit but it seems not possible. Please help
Thank you!
